Windows 10 update
ghindson
Windows 10 update
Thu Dec 10, 2015 11:50 am
Just updated to Windows 10, no real issues however even if I set M/Washer to start with Windows it does not start? Any ideas ?
Cheers,
Graham
ataraxy
Re: Windows 10 update
Fri Dec 11, 2015 2:56 am
Are you using an administrator account? I'm still testing Windows 10, but I've noticed that in my administrator account, programmes in the Startup folder don't start. In my standard account, programmes in the Startup folder start as expected.
So no guarantees, but if you're using an administrator account, try setting up a standard account and see if that helps. If it doesn't, try searching on "windows 10 programs in startup not starting" as there seem to be plenty of others with the same problem.
Windows 10
