Change folder options to view hidden files
Download and install a copy of Sqlitebrowser3.
Open Sqlitebrowser3 and find and open your MWP.db3 file. It is located in your C:\Users\user\AppData\Roaming\Firetrust\Mailwasher folder.
Choose File->Export and export your Friends or Blacklist to a CSV file.
Open with Excel and delete the record number (idx) and created_date columns. Save the file and close.
Open the file in Word, select all the document, and using search and replace, replace the string "[\w?.""-@]+@ with nothing.
Using search and replace, replace all backslashes \ with nothing.
You should now have a csv file with your Friends or Blacklist.
It's a lot of steps, but beats cutting and pasting.
Export Friends List Mailwasher Pro 7.5 To a Text File
- dickabbott
- Sidewinder
- Weary Womble
Re: Export Friends List Mailwasher Pro 7.5
You can also use the Export function in MWP, top right under file to do the Export.
- dickabbott
It does not appear that you can export in a format other than MXP.
Some of us would like the friends or black lists in a text format for use in other programs.
- Sidewinder
- Weary Womble
Understood. Thought maybe you were attempting to replicate the info in MWP on another computer.dickabbott wrote:It does not appear that you can export in a format other than MXP.
- jdtimer
Re: Export Friends List Mailwasher Pro 7.5 To a Text File
Hi, I have been a user of MailWasher for years and currently have 7.8 installed. Like others here, I wish to have my Friends list as a Text file that I can manually edit / update and 'import' or place back within the MailWasher. I do not appear to have a MWP.db3 within the location suggested above (yes, all hidden files revealed), possibly this has changed since 7.5 ? The export / import function is fine if migrating your MailWasher but I just want some text file ability, editability and control.. ie ability to work with my friends list outside of MailWasher Pro.
Hoping someone here can suggest a way to deal with this.. It should remain as easy as before, not more difficult !!
Much appreciated,,, john T
- jdtimer
Incidentally, I did note Dick Abbott's comment above.... is that valid to MailWasher Pro 7.5 or up to the latest version ?
- TrustFire
Navigate to Help >>----> User Files... >>----> (in the Explorer window that pops-up, click) >>----> cache (now, you should be seeing the MWP.db3 file.)jdtimer wrote:I do not appear to have a MWP.db3 within the location suggested above (yes, all hidden files revealed), possibly this has changed since 7.5 ?
I'd suggest using Filters instead of the Friends List (or Blacklist) — in addition to the editing you desire, check out some other advantages, as well.jdtimer wrote:Hoping someone here can suggest a way to deal with this..
