Hello, this is probably totally not possible but I have a set of email accounts I would like to have in a separate instance of the program.
In other words I would like to have 2 open at once with different accounts. Outside of a VM is there anyway this could be done?
Dual Instances
- TrustFire
Re: Dual Instances
Not sure why you might want to peruse some e-mail accounts separately . . . . . . . . . but, if the means justifies the end for you, the only way I see, is to make an additional investment into the V6 — it's an entirely different MWP edition which works independent of the V7 and can co-exist and also be run and operate together with your existing V7, without any harm.
The V6 is being discussed here.
- Sidewinder
- Weary Womble
Re: Dual Instances
Are you asking for two different devices or on the same device?
