I was running MW Pro 7.5.0 and did a check for updates and it didn't find any, even though 7.9.0 was out. My registration expires in July and I thought this meant that I was going to have to pay to upgrade. I went ahead and downloaded 7.9.0 and let it install and when I checked About it still shows my registration expires in July. So it appears to have upgraded my current version to the latest.
Was there a bug in 7.5.0 that kept it from seeing updates and if so, will 7.9.0 see updates when I have it check?
I really like the program as it has made my spam filtering so much easier.
Mike
Upgrade From 7.5.0 to 7.9.0
Re: Upgrade From 7.5.0 to 7.9.0
Yeah occasionally MailWasher seems to get stuck, if you go into Settings >> General >> Updates >> click Go To Folder >> delete the updates.aiu file and updates.aiu.part if it's present
