Good morning,
I have recently upgraded my very old Mailwasher 6.5.2 (I think) with a lifetime licence for 7.9.0 (current version). Long time overdue. Great product.
It is likely I will either update my aging Windows 7 laptop before too long or buy another computer.
When I go to install Mailwasher on the new machine, are there any complications (like having to install the older version first or use my old licence key first) or do I simply do another download of 7.9.0 (or use previously saved download) and then register my recent lifetime key for 7.9.0 on the new installation?
Advice very much appreciated
Happy days
PJ.
Installing Mailwasher 7.9.0 on a new or extra computer
Re: Installing Mailwasher 7.9.0 on a new or extra computer
Nope, pretty much install 7.9, put in the license and you're good to go.
MailWasher 7 too has a back up feature, under File >> Export >> you can create a backup file of your settings etc...
So if you're setting up on a new machine, but already been using MW7. Create the backup file first, then install MW 7 on new machine, then run the backup file on the new machine and MW will do the rest.
- pjfollyfarm
Very helpful & useful tip. Many thanks......
Happy days
PJ.
Happy days
PJ.
