Hi guys,
I've recently had problems with my Gmail account and my email client (Outlook 2016). In trying to repair things MW has started to download mail from my Gmail account that is six years old and I don't understand why it is doing this or how to turn it off. Help and advice would be really appreciated.
Carl
MWPro7.9 getting mail 6 years old - why?
- MightyMouse58
Re: MWPro7.9 getting mail 6 years old - why?
Hi Carl
You've got a few options.
In MailWasher you could use IMAP instead of POP, doing that would mean MailWasher will load all emails in the GMail Inbox that are Unread. You can set that under Settings >> Accounts >> Incoming.
You could continue to use POP in MailWasher and use Recent Mode, this is a GMail feature that will load emails from the last 30 days. To activate that you add recent: to your username in the same section mentioned above. Your username should then look like recent:username@gmail.com
You could change your GMail POP settings here https://mail.google.com/mail/u/0/#settings/fwdandpop and select the option "Enable POP for mail that arrives from now on"
- MightyMouse58
Thanks Rusticdog,
I tried your suggestion but that didn't work first up. I ended up uninstalling MWPro and removing my Gmail account from the system. BTW I'm running Win10Pro with OL16 as my email client. Also I previously had my Gmail account setup in OL as a POP account.
I have now reinstalled MWPro and re-established my Gmail account as an IMAP account. I'm no longer getting email that years old so that part is fixed, however when I wash my email after checking, the email I had marked for deletion disappears (which is good) but it leaves all my other email in the window so that they appear on the next check, even if I've downloaded them. I've checked all the settings and can't see anything wrong but I feel I've missed something - any advice?
- Sidewinder
- Weary Womble
Check your settings in OL to make sure that you do not have "Leave A Copy on the Server" selected.
If you're using IMAP in Outlook then this will happen as IMAP leaves messages on the server. MailWasher by default (when also using IMAP) will only load emails in the Inbox folder that are Unread. So options would be to move the emails out of the Gmail Inbox folder, or mark them as read, both those would cause MailWasher not to keep them in view.MightyMouse58 wrote:Thanks Rusticdog,
- MightyMouse58
Thanks Rusticdog, I'll check that out. Apologies for the delay in coming back.
