This issue has now been constant since I restarted my computer some days ago.
it seems to hang for hours at a time.
I need to press "stop" then wash mail.
Then it reverts to the same behavior again.
I have eight email accounts, six are my own domain name POP3.
One is gmail and the other is my isp.
Any help is appreciated.
Programs stalls evaluating message
- TrustFire
Re: Programs stalls evaluating message
Can you provide the answers to the following 6 queries with full details:—
- By "hang for hours" do you mean during loading or while checking/processing mail?
- What is the total number of e-mail accounts that has been set on MailWasher?
- On the server of those accounts, what is the total number of mails that are waiting to be audited?
- What is the version of your MailWasher?
- What are your hardware specifications?
- Which Operating System are you running?
- deramon
The message at the bottom left of the program says "Evaluating message:2590 of 2590 Stop (in red)
From Sunday night 8pm to Monday morning the same message.
As stated in the original message;
I have no idea.
How can that information be obtained?
7.7.0
?? Windows intel i7, 12GB memory, SSD drive
Windows 7 Pro
I have no idea.
7.7.0
Windows 7 Pro
- TrustFire
Disable your pipelining function and report back whether it resolved the issue.
Also, you have posted in the wrong forum — if disabling pipelining fails to resolve the issue, you might want to post at the right forum.
deramon wrote:I have no idea.TrustFire wrote:On the server of those accounts, what is the total number of mails that are waiting to be audited?
You answered yourself — more than 2,590 mails.deramon wrote:The message at the bottom left of the program says "Evaluating message:2590 of 2590 Stop (in red)
The 7.7.0 is outdated — you might want to update your copy to the latest version.deramon wrote:7.7.0TrustFire wrote:What is the version of your MailWasher?
Moved thread into the right forum.
deramon, can you send me some logs, if you go Help >> Send Support Logs >> enter a brief note like 'stuck checking mail' >> in the Ticket Number field enter chris >> Send Logs. Also reply back here once sent.
At a guess, MailWasher is actually stuck checking one of your accounts, but giving the impression it is hung up on evaluating.
Great thanks. Does it improve at all if you disable the DNSBLs, under Settings >> Spam Tools >> Origin of Spam >> uncheck both >> restart MailWasher.
- deramon
Hi Rustic
Yes that did help and it does not stall.
Thank you
Thank you
OK, glad to hear that. I'm still confused why it's causing the stall, I'll do some digging and see if I can reproduce the fault.
