I got three times the message before Mailwasher opens.
See attached picture
error message when opening
- reh31
Re: error message when opening
That's an error I've never seen before...
I would first try and run a .NET Repair, you can download the utility from https://www.microsoft.com/en-nz/downloa ... x?id=30135
If that does not work, I would then try running a System File Scan, that can repair damaged system files. Instructions on how to do that can be found here http://www.thewindowsclub.com/how-to-ru ... ws-7-vista
