I have 3 monitors.
What is it going to take for Mailwasher to open in my preferred monitor ?
For some reason it now always opens in my 3rd monitor (the rightmost)- my least preferred of the three.
I want it to always open on startup of Windows 7 on my leftmost (designated monitor 1).
Thanks.
Mailwasher keeps opening in wrong monitor
- JezUK
Re: Mailwasher keeps opening in wrong monitor
So if you move MailWasher to the monitor you want, File >> Exit >> when MailWasher starts it again opens on the wrong monitor ?
- JezUK
And then, if I move it to my first monitor, check mail, use it etc, then exit out of the program. When I restart the program (not restarting Windows) it still goes to the 3rd monitor.....
Exactly !rusticdog wrote:So if you move MailWasher to the monitor you want, File >> Exit >> when MailWasher starts it again opens on the wrong monitor ?
OK.
Can you first install this version and verify the problem still exists. http://cdn.firetrust.com/downloads/mail ... 042017.exe
Assuming it does (which I believe it will, but want to be 100%), then flick me some logs, if you go Help >> Send Support Logs >> enter a brief note like 'opening wrong monitor' >> in the Ticket Number field enter chris >> Send Logs.
Reply back here once sent, so I can be they've arrived.
- JezUK
No need.
I fixed it - nothing to do with Mailwasher - it was a 3rd party piece of multi-monitor software taking care of things.
My apologies.
My apologies.
Great, glad you got it sorted.
Just occurred to me, the custom MailWasher window may be conflicting. You could try disabling that under Settings >> Display >> remove the check mark from 'Enable custom window border' >> Save. It's possible with that off, MailWasher will behave with the third party software.
- JezUK
Now, with that setting disabled, MW behaves as I need it to, for example when wanting it to maximise to half of a screen (by 'force moving' it to a monitor's left/right/top/bottom edge) - it now does that faultlessly .
Many thanks for that great, great, great tip
Thank you so much for informing me of that feature - damn, I've had MW for at least 10 years and I've always had that "on" - giving me a custom MW interface which wouldn't behave as my other software and needing me to manually size the MW interface.rusticdog wrote:Just occurred to me, the custom MailWasher window may be conflicting. You could try disabling that under Settings >> Display >> remove the check mark from 'Enable custom window border' >> Save.....
- Digerati
- Microsoft MVP
For the record, I have a dual-monitor setup. I have "Enable custom window border" checked. MWP always opens on my secondary monitor like I want it too.
As for 3rd party software, not sure what type you are referring to, but I use Ultramon to give me better control over my multimonitor setup but I have not made any special settings for MailWasher specifically.
W10 Pro 64-bit
MSI R7 370 2GD5T OC card using DVI to both monitors.
W10 Pro 64-bit
Bill (AFE7Ret)
Freedom is NOT Free!
- Tetrol
Hve been using Mailwasher for too many years to remember, and it always opens on my primary monitor (where I do not want it). If I click on the button to change to windowed view it shoots across to the secondary monitor wher eit can be re-expanded to full screen. It stays put there until I restart the computer.
I thought I would change the suggested setting - the only change I got was that when I click on the windowed view it stays on the primary monitor and has to be manually moved across - a net loss to me.
Any suggestions? My dual monitor setup is run via windows/nvidia, no other related software in use. Email, internet (Firefox, IE and Google Chrome) , MS Office applications all behave themselves and open on the last screen they were used.
