Guys, I would really appreciate some help setting up a filter to block a particular type email--they all end in .nl. For instance:
@otohemineurasthenia.eticast.nl
serenoas@componency.newsbow.nl
silentiary@nongrained.percepus.nl
I used the pro version for a couple of years, but I am about to retire and will not be able to afford it so I let it go. Now, I am using MailWasher Free ver. 7.90. I am being bombarded by spam, but it is all from one main source with a zillion variations I tried to figure this out, but it is just beyond me. Would anyone be willing to help? I would be so grateful.
Thanks, a granny in Texas
Granny needs up configuring a filter
- TrustFire
Re: Granny needs up configuring a filter
- TrustFire
For maximum effectiveness, you might want to ensure that the filter suggested on my previous post is elevated to the very top of the food-chain by using the Filter priority pyramid arrow, as illustrated below:—
- Donna77642
Thank you so much for the help!!! Not only are you generous with your time, you are gracious in sharing your talents! I appreciate it!
- TrustFire
Have made a slight improvement in the filter on my first illustration — just tightened-up the rule a little bit to reduce false positives.
- Donna77642
