Date between emails
- iamthegun
Date between emails
How do I remove the date between emails. I want them all together not separated by date.
- TrustFire
Re: Date between emails
You can enable the Grouping Bar to check whether removing the Received (or Arrived) header helps.
Once your issue is resolved, you could (disable your Grouping Bar if you wish to.)
- Digerati
- Microsoft MVP
Have you tried just sorting on the various categories - "From" for example? You can also remove Sent and Received from being displayed completely.
Bill (AFE7Ret)
Freedom is NOT Free!
