Remove "Today" and "Yesterday" from Inbox window
bardos
Fri Jun 09, 2017 7:31 am
Version 7.11, how do I remove "Today" and "Yesterday" from Inbox window. It is not obvious to me how to do this. Maybe this is a permanent feature , I do not know, thx.
Re: Remove "Today" and "Yesterday" from Inbox window
Fri Jun 09, 2017 7:46 am
You can enable the Grouping Bar to check whether removing the Received (or Arrived) header helps.
Once you're satisfied with the sorting, you could (disable your Grouping Bar if you wish to.)
bardos
Fri Jun 09, 2017 9:48 am
Not sure this answers my question. Screenshot below. How do I get rid of all that "Today" stuff and just see the data?
Digerati
Microsoft MVP
Fri Jun 09, 2017 1:44 pm
I don't think you can. It shows the date and time stamp. For today it says "Today". For yesterday and before, it show the actual date. If you don't want any of that, remove that column from view.
Image Bill (AFE7Ret)
Freedom is NOT Free!
bardos
Fri Jun 09, 2017 2:27 pm
It does not appear to be a "Column", it's some add-in in the inbox area that I don't want at all. Can someone tell me how to get rid of this?
Fri Jun 09, 2017 4:50 pm
Right click on the Received column heading >> remove the check mark from 'Group By Received'
Fri Jun 09, 2017 5:19 pm
bardos wrote:Not sure this answers my question. Screenshot below. How do I get rid of all that "Today" stuff and just see the data?
<snip>
Your screenshot does not show your Grouping Bar, as enabled. :|
Fri Jun 09, 2017 5:31 pm
TrustFire wrote:You can enable the Grouping Bar <snip>
Have included a graphic illustration to the post on my original link — publishing the same here, as well:—
