I am a very experienced computer user so it will come as no surprise to you that I have accidentally formatted my hard drive . Luckily it is not my boot drive, but it is the one that I installed Mailwasher to. I can recover the files but I need to know the file names of the ones that would have been backed up if I had used the Mailwasher backup option. I have to restore them one at a time. Doh!
If anyone can give me a list of the files I need to copy across to the new installation, I will be for ever grateful! Thank you in advance
Directories / Files
- TrustFire
Re: Directories / Files
If you indeed used the MailWasher backup (export) feature, you would have one single file (named by yourself) — the file extension would end with the .mwp format.
The directory to restore if possible is C:\Users\[your username]\AppData\Roaming\Firetrust\MailWasher\
That's all your settings etc... and then you just need to re-enter your license.
Failing that, and assuming you are doing files one at a time then the important ones are listed below.
In C:\Users\[your username]\AppData\Roaming\Firetrust\MailWasher\
Accounts.xml
Display.xml
Filters.xml
GeneralSettings.xml
RecycleBinSettings.xml
SpamReporting.xml
SpamToolSettings.xml
Startup.xml
And in C:\Users\[your username]\AppData\Roaming\Firetrust\MailWasher\cache
MWP.db3
Accounts.xml
Display.xml
Filters.xml
GeneralSettings.xml
SpamReporting.xml
Startup.xml
MWP.db3
- DeskPilot
Hi rusticdog, that's exactly what I need, thank you.
After extensive internet searches, it seems it is not possible to restore whole directories and their contents - just individual files. I have some software that recovers lost files but It's still a drag. My fault entirely though. Your help is greatly appreciated.
- TrustFire
In order to insulate one's copy from such problems, it's better to migrate one's User Files... directory from the default system volume (C:\) to the logical partition (D:\ or such.)
- DeskPilot
Yes, absolutely. My Drive C was the boot drive and all documents, photos, programs etc were redirected / installed on Drive F:/. This was the drive I accidentally formatted. So, I now have an external drive and the data files from this and other programs will be backed up on here. Thank you again Mailwasher is now up and running again. Cheers
