How to Remove Splash Screen
pegasus44
Postby pegasus44 Sat Aug 07, 2010 2:31 am
I have seen two mentions of "-nosplash"
I do not know how to use the Command Line. Also I do not open MW from a short cut.
I use a programmable keyboard where I have entered the path to mailwasher.exe
i.e. "C:\Program Files (x86)\FireTrust\MailWasher\MailWasherPro.exe"
I should be grateful for a simple instruction. Of course, it would be easy if there was a box to untick in 'Settings'.
michaelkenward
Guardian Gecko
Re: How to Remove Splash Screen
Postby michaelkenward Sat Aug 07, 2010 2:45 am
If the keyboard shortcut allows it, the way to use switches is:
"C:\Program Files (x86)\FireTrust\MailWasher\MailWasherPro.exe" -nosplash
Seems to work for MW2010. It was something I was thinking of looking into earlier. Thanks for the pointer.
MK
Windows 10 Pro 64-bit | Asus M5A88TD-M EVO + AMD Phenom II X6 1055T + 8GB Corsair XMS3 1600
Postby Sidewinder Sat Aug 07, 2010 4:34 am
pegasus44 wrote:I have seen two mentions of "-nosplash"
Corrected (My Bad added the space where needed):
michaelkenward
Guardian Gecko
Postby michaelkenward Sat Aug 07, 2010 4:50 am
Sidewinder wrote: "C:\Program Files (x86)\FireTrust\MailWasher\MailWasherPro.exe-nosplash"
This may work, the one I offered definitely works. I tried it.
The quotes have to be in the right place.
You need them because there are spaces in the path. In this case in "Program Files (x86)".
In essence, the quotes say "Here is the program".
Including the switch inside the quotes can break the command.
MK
pegasus44
Postby pegasus44 Sat Aug 07, 2010 7:45 am
michaelkenward wrote:If the keyboard shortcut allows it, the way to use switches is:
This worked perfectly. I noted the leading space before -nosplash
Corrected:
"C:\Program Files (x86)\FireTrust\MailWasher\MailWasherPro.exe"-nosplash
Since the first attempt was functional I did not try without the leading space.
Thank you both for your prompt replies.
When a switch is required again I may be able to implement it.
Who is online
Users browsing this forum: No registered users and 2 guests
