Mail returns after processing unless deleted in Mailwasher
JFA
Fri May 25, 2012 7:56 pm
I am running Mailwasher 6.5.4 in conjunction with Outlook 2010. I have upgraded from 4.6 and Outlook express. When I process mail, it is sent to Outlook but is not deleted from Mailwasher. With my old programs, once the mail was processed, it was removed from Mailwasher, now I must select delete to remove each message. After trawling these forums, I have checked for anything on Outlook that might tell mail to stay on the server but can't find anything. My account is a POP account. Any suggestions, i'm sure it is something simple and something that I am doing wrong.
Re: Mail returns after processing unless deleted in Mailwash
Fri May 25, 2012 8:16 pm
JFA wrote:I have checked for anything on Outlook that might tell mail to stay on the server but can't find anything. My account is a POP account. Any suggestions, i'm sure it is something simple and something that I am doing wrong.
Check the illustration at the following post - you'll be fine. :thumbsup
http://forum.firetrust.com/viewtopic.ph ... 547#p65787
JFA
Fri May 25, 2012 10:22 pm
Thank you, that has worked. The picture was of, I think, Outlook 2007. 2010 is slightly different.
For those that follow:
Open Outlook
Select File then Info then Account settings
Highlight your account and select change
Select more settings then the advanced tab
Uncheck "leave a copy of messages on server"
Fri May 25, 2012 10:28 pm
JFA wrote:Thank you, that has worked. The picture was of, I think, Outlook 2007. 2010 is slightly different.
That's actually Outlook 2010 Pro Plus on a tweaked Windows skin - glad the illustration worked for you. :)
JFA
Sat May 26, 2012 12:02 pm
If you can tweak Outlook to that extent, perhaps you can tell me how to simplify the way it looks, I really was much happier with Outlook Express, no longer available with Windows 7. I know this is a Mailwasher forum so you don't have to answer. Thanks again for sorting out my problem.
Pierre
Sat May 26, 2012 1:07 pm
Outlook Express is replaced by Windows Live Mail but you have to download and install it. It does not come as part of Windows 7.
Sat May 26, 2012 1:41 pm
JFA wrote:I know this is a Mailwasher forum so you don't have to answer. Thanks again for sorting out my problem.
No problem at all, once the main business is accomplished - it's quite fine to go off-topic. :)
JFA wrote:If you can tweak Outlook to that extent, perhaps you can tell me how to simplify the way it looks, I really was much happier with Outlook Express, no longer available with Windows 7.
Was brought up on Outlook Express, myself - but, as Pierre mentions very rightly it's been displaced in Windows 7.
About the Outlook 2010, I have not tweaked it in any way - it's the Windows theme that has been changed (this affects all programs globally, including Outlook.) :)
