Log subject "Failed to log in to IMAP server"
Andrew Dillon
Fri Nov 09, 2012 4:54 am
Not sure whats meant by MW 5 & 6 - mines v2012 1.20.0.
Before reinstalling Win7, MW checked mail without any prob. Since reinstallation, Ive had error msg in Subject.
Importing settings from when it worked doesnt make any difference. I have same IMAP settings as Thunderbird.
Thx for any help you can give.
ataraxy
Re: Log subject "Failed to log in to IMAP server"
Fri Nov 09, 2012 5:40 am
Andrew Dillon wrote:Not sure whats meant by MW 5 & 6 - mines v2012 1.20.0.
The forum for your version is viewforum.php?f=50
When you repost, could you please include more detail. I couldn't figure out what the problem is.
Windows 10
Fri Nov 09, 2012 6:23 am
Andrew Dillon wrote:I have same IMAP settings as Thunderbird.
Screenshots of those MWP settings posted at the appropriate forum might help. ;)
