Hi....I have several hundred friends listed in another anti spam program and would like to put them into MW.
Anybody got a way....
Many Thanks....Ponder
Import Friends list
- TrustFire
Re: Import Friends list
Can tell you the location of the default MWP 'Friend's List':-
C:\Users\YourUserName\AppData\Roaming\Firetrust\MailWasher\cache\MWP.db3
You may experiment with MWP.db3 (at your own cost) by right clicking and opening it with Notepad. Please note the MWP.db3 also contains other relevant data (and is easily corruptible.)
- Ponder
Thanks for this idea....Can't locate this file....could it be somewhere else?
Thanks..
Thanks..
- TrustFire
That location is applicable to Windows 8, Vista and Windows 7.
If you're running any other OS, try the following:-
From the GUI of your MWP Inbox, navigate to Help >>----> User Files... >>----> (in the Window that opens before you,) >>----> cache >>----> MWP.db3 (if you still cannot see MWP.db3, disable hidden files at your 'Folder Options.')
- Ponder
Thanks again...Win XP found it at Docs and Settings>>>user name>>>App Data>>>>Mail Washer Pro>>>Blacklist.txt
Interesting the friends are listed in the black list file??..
Thanks again.....copied a few friends from the old program into this folder and it worked great....
- TrustFire
Ah, that's not the MWP version that's supposed to be discussed, here - what you're using is a older & unsupported version. Glad your issue is resolved.
The Blacklist.txt is available only in the older version that's discussed at the following link:—
Ponder wrote:Thanks again...Win XP found it at Docs and Settings>>>user name>>>App Data>>>>Mail Washer Pro>>>Blacklist.txt
