MWPro 5.0.
Filters and other data are located in C:\Documents and Settings\USER\Application Data\MailWasherPro, as by default.
I want to move this MailWasherPro folder to a new location on my drive so I can control backups... for example C:\Main\CustomPrograms\MailWasherPro.
Any way to do this and have MWP find this new location?
Thanks,
Steve
Move MailWasherPro folder from default location
- TrustFire
Re: Move MailWasherPro folder from default location
Instead of trying to moving the default location of the User Files, I prefer to synchronize them with a location on the D:\ drive.
- squeegybug
I appreciate your reply.
I assume you mean sync using a backup tool?
Yes I could do this but I'm not really too concerned about continuous mirroring, just using a daily discrete backup.
And wanted my MWP files in the same data location as all my other backed-up files.
This is the only application I use that stores needed data in these arcane labyrinth Windows app locations.
Thanks,
Steve
Thanks,
Steve
- TrustFire
ATM, the V6 iteration of MWP is no longer being developed and I don't see that option happening — that's possible only with the latest V7 (check out the illustration at the following link):—
