I cant uninstall MailWasher Pro
Newsy
Postby Newsy Sun Jun 23, 2013 6:57 am
I'm trying to uninstall the program because I'm getting the message: "List index out of bounds" but no matter which route I use to uninstall I'm getting "C:/ProgramFiles(x86)/Firetrust/MailwasherPro/unins000.dat. does not exist. Cannot uninstall."
What do I do now? :rant
Joan Lalonde
Pierre
Prudent Pukeko
Re: I cant uninstall MailWasher Pro
Postby Pierre Sun Jun 23, 2013 4:26 pm
I did a search for you under MW 5&6 and came up with these results. Think from memory you may have corrupt file.
search.php?keywords=list+out+of+bounds&terms=all&author=&fid%5B%5D=13&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
Postby TrustFire Sun Jun 23, 2013 6:29 pm
Newsy wrote:I'm trying to uninstall the program because I'm getting the message: "List index out of bounds" but no matter which route I use to uninstall I'm getting "C:/ProgramFiles(x86)/Firetrust/MailwasherPro/unins000.dat. does not exist. Cannot uninstall."
Joan Lalonde
Re-install MWP and if required it will then have the option to uninstall.
Who is online
Users browsing this forum: No registered users and 10 guests
