unable to open mailwasher
sloppy33
Tue Aug 13, 2013 6:58 am
I have just purchased mailwasher pro and although it appears to be working well on my primary computer but I am unable to open it on my second computer. I have the license number but cannot open the program to input it. Any suggestions please. :?
ataraxy
Re: unable to open mailwasher
Tue Aug 13, 2013 1:21 pm
Try reinstalling it.
Windows 10
sloppy33
Tue Aug 13, 2013 5:21 pm
I have already tried deleting and reinstalling twice, but thanks for trying to help.
Tue Aug 13, 2013 5:57 pm
Did you try looking in your System Notification Area to find out whether MWP is actually starting but hidden away?
Is MailWasher.exe running as a background process under Task Manager?
Did you try disabling your security system . . . . . temporarily?
What is the error you're getting - screenshot(s), please.
Are you running the V6 or the V7?
sloppy33
Tue Aug 13, 2013 6:22 pm
There is nothing in my system notification area or in the task manager, as for a screenshot, how do I take a screenshot of nothing? I am getting no error messages. I have opened a dialogue with Jeremy of Firetrust Support #MOF-543021 so hopefully he may come up with an answer.
Tue Aug 13, 2013 6:28 pm
sloppy33 wrote:There is nothing in my system notification area or in the task manager, as for a screenshot, how do I take a screenshot of nothing? I am getting no error messages.
You've answered just two of the four questions raised. ;)
sloppy33 wrote:I have opened a dialogue with Jeremy of Firetrust Support #MOF-543021 so hopefully he may come up with an answer.
:thumbsup
sloppy33
Tue Aug 13, 2013 7:01 pm
Sorry for not answering all your questions, getting a bit frustrated now...I have deleted MW Pro yet again and reinstalled it with my security turned off..no difference. As for the version, how the hell do I find that out, I only bought the blooming program yesterday so I ought to have the latest version don't you think.
Tue Aug 13, 2013 7:20 pm
sloppy33 wrote:As for the version, how the hell do I find that out, I only bought the blooming program yesterday so I ought to have the latest version don't you think.
Both the V6 and the V7 are the latest versions of two different iterations - now, don't you think you could've clicked my links to find out (especially since you've posted at the V6 forums instead of the V7 forums) :?:
Kindly stop venting out your frustration, here . . . . . . . OK - we're just MWP Users like you, who help others in our spare time. :ninja
sloppy33
Tue Aug 13, 2013 8:15 pm
Sorry you found my frustration irritating, as you are working under the name Trustfire I presumed wrongly as it happens that you were part of the company. I am a female novice and hoped I would be able to get answers to my problem here. Wrong again. I will move on.
Tue Aug 13, 2013 9:20 pm
sloppy33 wrote:As for the version . . . . . . .
sloppy33 wrote:it appears to be working well on my primary computer . . . . . . .
You can always use the version details from the MWP that's working fine on your primary computer:--
For MWP V7:
{At the top-right-hand-side} Help >>----> About
For MWP V6:--
{At the top-left-hand-side} Help >>----> About
sloppy33 wrote:I am a female novice and hoped I would be able to get answers to my problem here.
The V6 and V7 are radically different from each other - without an accurate diagnosis, it would be akin to performing a surgery on the wrong patient . . . . . . . by the right panel of Doctors. :devil
sloppy33
Tue Aug 13, 2013 10:27 pm
checked that one out, for a change it was relatively simple once you told me how to do it. I have v7.2.0.
Wed Aug 14, 2013 12:27 am
sloppy33 wrote:checked that one out, for a change it was relatively simple once you told me how to do it. I have v7.2.0.
OK, great - let's get it working!!! :thumbsup
01.) Please navigate to C:\Users\YourUserName\AppData\Roaming\Firetrust\MailWasher
02.) Right click GeneralSettings.xml to open with Notepad and then rename and save the following 3 entries highlighted in red (at lines # 16, 17 and 18):--
  • Change
    <MinimiseToTaskbar>False</MinimiseToTaskbar>
    to
    <MinimiseToTaskbar>True</MinimiseToTaskbar>
    Change
    <MinimiseOnClose>True</MinimiseOnClose>
    to
    <MinimiseOnClose>False</MinimiseOnClose>
    Change
    <StartMinimised>True</StartMinimised>
    to
    <StartMinimised>False</StartMinimised>
    Don't forget to 'Save' the GeneralSettings.xml after you're done renaming the above 3 lines.
Now, try running your MWP. :thumbsup
sloppy33
Wed Aug 14, 2013 6:13 pm
Well first off I only got to 'roaming' because 'firetrust' was not there. But the partial good news is that I had an answer from firetrust support and they suggested that I may have a problem with my .net 4...didn't know I had one...and to run a repair job. I did this quite easily and MW Pro now opens, the difficulty is that it opens in the wrong resolution and then shuts down so one step forward and two back.
Wed Aug 14, 2013 6:34 pm
sloppy33 wrote:Well first off I only got to 'roaming' because 'firetrust' was not there.
Ah, the Firetrust directory only just gets created after the first MWP run — which, in our case just didn't happen.
sloppy33 wrote:MW Pro now opens, the difficulty is that it opens in the wrong resolution and then shuts down so one step forward and two back.
If I were you, I'd use an external medium such as a flash-drive or HDD to simply copy the entire directory from the following location of the working PC onto the same location at the PC that's not working. :thumbsup
Code: Select all
