MW cannot see my email client
kaysee
Sun Sep 01, 2013 7:07 am
I had to reinstall Mailwasher Pro 6.3 on my laptop (WIndows 7). I used the wizard to set up my email account and was able to look at my emails. However, when I came to click on the Process or Mail Program button I get a message stating that MW cannot find my email program (WIndows Live Mail). I then went into the program settings and selected WIndows Live Mail manually from General Option (it was the only program listed) and then used the test button. Windows Live Mail opened using the test button but would still not open using the Process Mail or Mail Program buttons. I tried uninstalling and reinstalling MW but got the same result. Help please.
ataraxy
Re: MW cannot see my email client
Sun Sep 01, 2013 8:33 am
First, try the latest version v6.5.4 which you can get at http://www.firetrust.com/products/mailw ... 6/download
If that doesn't work I'd suggest contacting Firetrust Support via http://support.firetrust.com/ to see if they can help. The problem is, since this version isn't being actively developed, issues like this can occur and won't be fixed.
Windows 10
