Missing Thunderbird dll files
Being
Fri Sep 13, 2013 6:25 am
I've seen other posts concerning this problem but none of the suggested solutions worked for me. I'm running Win7 Enterprise 64bit.
Mailwasher Pro (6.5.4) is unable to import my Thunderbird (17.0.8) account settings because it can't find the following .dll files: mozglue, nspr4, plc4, mozsqlite3 and nssutil3.
All of those files are present in the root directory of Thunderbird.
Any suggestions please?
ataraxy
Re: Missing Thunderbird dll files
Fri Sep 13, 2013 2:09 pm
Thunderbird has changed the format that is uses to store details like this and therefore v6.5.4 isn't able to import them.
As v6.5.4 isn't being actively developed, there is no solution to this.
Windows 10
Being
Sun Sep 15, 2013 9:57 pm
Thanks ataraxy.
