Just moved to Windows 7. MW 6.5.4
I have my blacklist (whitelist) located at E:\_7Documents\Mailwasher\Blacklist.txt. In MW I have pointed the My friends list and My Blacklist to this file. It does not get updated.
I also have a blacklist located at C:\Users\ron\AppData\Roaming\MailWasherPro\Blacklist.txt. This file seems to be updated (The Modified Date changes). However, when I reboot MW doesn't appear to have updated the Blacklist.
Is there a way to make MW update the file located at E:\\_7Documents\Mailwasher\Blacklist.txt?
I have changed the properties (under Compatibility) to run as Administrator.
Blacklist not updating
- hashky
Re: Blacklist not updating-[Solved]
I deleted the file E:\_7Documents\Mailwasher\Blacklist.txt.
Then I opened MW and deleted the file reference to the above file.
Tools->General Options->My blacklist->List Options
MW is now working as it should .
I kissed a lot of frogs before I found the Princess.
