Are you saying that the spam that you've washed in MailWasher is appearing in the Incredimail spam folder?
It would also help to know whether you are using POP3 or IMAP to access your email in MailWasher and Incredimail.
Mail Washer With AT&T And Incredimail 2.5
- ataraxy
- Knowledgeable Kea
Re: Mail Washer With AT&T And Incredimail 2.5
Are you washing the mail in MailWasher so that the spam is deleted?
If you are washing the mail, what happens if you check mail in MailWasher after the wash? Is the spam still there?
Also, rather than setting up filters as you are doing, if you use the learning function in MailWasher, it will soon learn that email like that is spam, and mark it for deletion automatically.
Windows 10
- ataraxy
- Knowledgeable Kea
This is what you need to do.
You must check and wash your email in MailWasher before you download it to Incredimail. If Incredimail is set to download email automatically, you'll find it easier if you turn this off, and download mail to Incredimail manually, after you've washed it in MailWasher.
steelersjourney wrote:I Wonder If I Set Spam Washer To See The Email First Before Incredimail Downloads It ,Might Help ?
Windows 10
