Messages Stay in Mailwasher After Download
angelah
Wed Apr 16, 2014 4:35 am
I set up two new accounts. One works fine and downloads the messages. The other is keeping the messages in Mailwasher AFTER the download.
I checked the settings and they seem exactly the same as my other accounts, so I must be missing something. Please advise. THANK YOU in advance.
Re: Messages Stay in Mailwasher After Download
Wed Apr 16, 2014 4:45 am
Have already answered this same query at your following topic with no response (as usual):--
angelah
Wed Apr 16, 2014 5:42 am
As usual? You must be having a bad day and need to lash out at someone. Find a new punching bag.
Question was reposted because I could not find the post after a brief power outtage.
But since you need the pat on the back, kudos, and praise and the "THANK YOU in ADVANCE" was not good enough when I barely had to check back
and reply while I'm at work: Let me be the first to say THANK YOU for taking the time from your busy day to provide a reply. Hope your day gets better.
No need to reply, I won't be checking back.
Wed Apr 16, 2014 11:01 pm
angelah wrote:As usual? You must be having a bad day and need to lash out at someone. Find a new punching bag.
Yes, as usual — just to cite a few of your topics where you've failed to report back (do let me know if you want me to post some more examples of your discourtesy):—
angelah wrote:Question was reposted because I could not find the post after a brief power outtage.
. . . . . . . . or maybe — because you realized that initially you had posted in the wrong forum.
angelah wrote:But since you need the pat on the back, kudos, and praise and the "THANK YOU in ADVANCE" was not good enough when I barely had to check back
Your "THANK YOU in ADVANCE" means nothing to us — all that we expect is to be able to quickly alleviate folks from their problems (not limited to MWP, example — this topic, itself which is actually a Outlook mis-configuration that has got nothing to do with MWP.)
When you report back about which one of those solutions worked for you, you're doing others a favor (not us) — others, who (in future) might come across the same issue as you did (only, unlike you — most, who would probably bother to use the search function before posting an SOS.)
So well, you may keep your "THANK YOU in ADVANCE" to yourself.
wilky1
Re: Lose main body and attachments of emails after using restore.
Sat Jul 30, 2022 4:47 pm
Hi, I have a problem of emails after using restore. I have inadvertently on several occasions deleted emails by rushing too quickly through them in Mailwasher and upon using the restore function I find both the body of the email and any attachments are not restored with the email. Is this normal or am I doing something wrong? I am using a VPN, does this make a difference?
Regards, wilky1.
