Mailwasher 6.5 4 restore email
berniebee
Sun Jul 20, 2014 4:33 pm
Hi
i have tried on numerous occasions the restore email function to come up with this error as show
I have read the forums on how to retrieve deleted emails but it does not work.
Any help appreciated please.
screen error.jpg (50.74 KiB) Viewed 2592 times
Re: Mailwasher 6.5 4 restore email
Sun Jul 20, 2014 6:51 pm
You can open an account just for Restore purposes with Gmail - it is free and trouble-free.
You can then try the step-by-step graphic illustrations at the following post:--
Mon Jul 21, 2014 3:40 pm
Looking here Bernie, it doesn't look like SSL is enabled for iHug/Vodafone
http://help.vodafone.co.nz/app/answers/ ... e-%26-ihug
So under Settings >> Recycle Bin Options >> Set SMTP Server >> Advanced >> you want the port number to be 25 >> Secure Connection Type to be set to NONE >> and SMTP Authentication unchecked.
berniebee
Mon Jul 21, 2014 11:23 pm
Thanks.
I have got it working with GMail which is a bit of a pain.
Will give this option a try now. :)
