Error "No default Email application was found"
TazD
Sun Nov 30, 2014 5:29 pm
Hi, I can 'check mail' no problem, but when I press "Mail Program OR Process Mail" it comes up with the message "No default application was found". I use Thunderbird 31.2.0. In Thunderbird, Options-> Advanced ->General, I have System Integration "Always check to see if Thunderbird is the default mail client on Startup" TICKED. I have Mailwasher Pro 6.1 and Windows 7. I run WIZARD and nothing shows up. Under Mailwasher Pro in General Options -> Email Accounts -> INCOMING MAIL" I have "Include this account in default mail check" ticked. Any help would be greatly appreciated. I can "Check Mail" No problems. Thanks.
Re: Error "No default Email application was found"
Tue Feb 24, 2015 3:19 am
Check out the following post (and also the entire thread) — the example illustrated is for a different e-mail client (The Bat Professional):—
