Hi, I have just done a clean install and re-set up and run Mailwasher 6.5.4 and I get the following error: Session encountered errors - first alert - invalid response, spam database might be offline.
I never had this issue before clean install.
(see attachment)
Many thanks
First alert - session encountered errors
- sabaithaime
- Mailwasher session encountered errors - first alert.PNG (34.93 KiB) Viewed 5074 times
Re: First alert - session encountered errors
Embedded in your registration key will also be your (optional) FirstAlert account, and if that has not been getting renewed then it will throw this error. Go into Tools >> Spam Tools >> FirstAlert >> you can disable it there.
- sabaithaime
Hi rusticdog,
Thank you for your prompt and helpful reply. Job done!
