Hi There,
I have just installed MailWasher on my PC, a complete newbie to out of client spam elimination, and my email client (as per signature) is eM Client. After the initial install process MW collected information on email accounts however it had found some "old old" MS Outlook account details rather than from the eM Client that is the current default, used email client.
Because the account settings that were found based on MS OUtlook - I cancelled at that point. My questions are:
1.How can I import the email accounts that are set up within eM Client? (apart from going through a manual process to install one-by-one). I have around 20+ email accounts to configure across 7 host domains.
2. Will MW recognise my IMAP accounts as well as my POP3 accounts?
Many thanks for any help.
Newbie: Need some assistance with email client recognition
- cmebd
MWPro 7.11.8
OS: Windows 7 (64 bit)
Mail Client: eM Client
Re: Newbie: Need some assistance with email client recogniti
Hi there
Unfortunately MailWasher doesn't support importing accounts from eM Client, so adding the accounts manually would be the only option.
