The pass word for my server was changed to comply with a new standard. Since then I have not been able to download e-mail. The apparent reason is that the password in Mailwasher 6.5.4 must be changed to be able to access the server but I have been unable to change the password in Mailwasher. I can type in a new password in the account profile but as soon as I leave the screen it apparently goes back to the old password. I tried deleting that account and establishing a new account but that did not solve the problem. Using the Wizard did not solve the problem.
Mail is piling up at the server and I cannot access it.
Your help will be appreciated.
Sincerely,
Slim2
Having trouble changing password for an account
- Slim2
Re: Having trouble changing password for an account
Slim2 wrote:The pass word for my server was changed to comply with a new standard. Since then I have not been able to download e-mail. The apparent reason is that the password in Mailwasher 6.5.4 must be changed to be able to access the server but I have been unable to change the password in Mailwasher. I can type in a new password in the account profile but as soon as I leave the screen it apparently goes back to the old password. I tried deleting that account and establishing a new account but that did not solve the problem. Using the Wizard did not solve the problem.
Sincerely,
Slim2
Not heard of that before, in MailWasher I assume you're in Settings >> Email Accounts >> and altering the password in the Incoming tab >> then be sure to hit OK to Save the change. It could be worth then exiting MailWasher through File >> Exit >> and restarting the program to ensure all alterations were indeed saved.
You could to try running the file attached, inside is show_pass.exe >> run this and hit the Refresh button >> it will how your passwords in your email programs >> just to be sure you're typing in the right password into MailWasher.
- password.zip
- (453.9 KiB) Downloaded 224 times
- Slim2
Dear rusticdog,
Thank you for your reply. I tried your suggestions without success.
I went to >>Settings>>Email Accounts>> and altered/changed the password at >>Incoming>>. I then had to go to >>Advanced>> to get where I could click >>OK>>.. This did not change the password. I then repeated this but continued to >>Outgoing>> in order to get another >>OK>>. This did not change the password. I then repeated the procedure and >>Exited Mailwasher>>. Started over and again the password was not changed. I can tell this by the number of characters in the password.
Next, I tried to use the password.zip that you provided. I was unable to get the server password to download. I am confident that the server password is correct because I can use it to log in to the mail on the server.
I am at a loss of how to proceed now. Your continued help will be appreciated.
Sincerely, Slim2
Sincerely, Slim2
- TrustFire
Perform the following operation at your own peril.
Navigate to and backup the following registry key before deleting the affected account listed thereunder and then recreate the same from scratch:—
- [HKEY_CURRENT_USER\Software\FireTrust\MailWasher Pro\Prefs\accounts]
MWP 7 (ßeta) | Windows 10 LTSC (20H2) | The Bat! Professional (ßeta) | Windows 10 Firewall Control (ßeta) | ESET Endpoint Antivirus (ßeta) | nVIDIA GeForce (GTX 1060) | Internet Connection Speed (4G USB tethering — VoLTE) | .NET Framework (4.8)
- Slim2
Thank you Trustfire for your response.
I am not at all familiar with editing the Registry. It would be my luck to foul everything up royally if I tried.
Best regards,
Slim2
Best regards,
Slim2
- Slim2
Dear rusticdog,
Have you had a chance to review my last reply to you? Is there any other info that I can furnish that may help define the problem further and the attempts that have been made so far to solve the problem ?
Sincerely,
Slim2
Dear rusticdog,
Is there another way I can contact you to try to get this problem resolved?
Sincerely,
Slim2
Sincerely,
Slim2
Dear rusticdog,
Sincerely,
Slim2
- Slim2
At the present time my Mailwasher appears to be working satisfactorily. I will continue to monitor this forum and hope the new Firetrust Overlords will permit me to do so.
