Spam still gets through
Kafka
Sat Mar 04, 2017 12:56 pm
i have been using Mailwasher Free for some time now and find it very useful. I use Mozilla Thunderbird and have found that over the last few months a folder Spam has appeared which inevitably contains large amounts of spam which have not shown up in Mailwasher. I always open Mailwasher before Thunderbird and routinely check and was my mail, so how come all this spam is getting through?
Re: Spam still gets through
Sat Mar 04, 2017 7:01 pm
As far as Gmail is concerned, the POP3 protocol in MWP cannot possibly access Gmail's Spam folder — in order to workaround this technical limitation, you can try this Gmail trick (please note — the screenshots are a bit outdated but the fundamentals remain the same.)
Kafka
Sat Mar 04, 2017 7:09 pm
How about with Mozilla Thunderbird?
Sat Mar 04, 2017 7:11 pm
What about Mozilla Thunderbird? :scratch
Kafka
Sat Mar 04, 2017 8:57 pm
The answer given above refers to Gmail, I use Mozilla Thunderbird so it doesn't help.
Sat Mar 04, 2017 10:16 pm
Kafka wrote:The answer given above refers to Gmail, I use Mozilla Thunderbird so it doesn't help.
Which one are you using, then — I thought I saw Gmail on your OP (sorry about that.)
Sat Mar 04, 2017 10:18 pm
Also, which protocol (POP3 or IMAP) are you using on your MWP and also on your Mozilla Thunderbird?
Please provide details.
Kafka
Sun Mar 05, 2017 11:03 am
I use Thunderbird. I am using IMAP on Mailwasher (though I didn't select it) but I am not sure about Thunderbird as I have been unable to find out so far.
Kafka
Sun Mar 05, 2017 11:08 am
I am using POP and IMAP in both Mailwasher and Thunderbird.
Mon Mar 06, 2017 2:52 am
Unless you have the need to view your e-mails from multiple computers/devices, would suggest converting your IMAP protocol on Mozilla Thunderbird to POP3.
If you had answered this one, too — would have been in a position to suggest better options.
In case you are on Yahoo! you need to use IMAP on MWP instead of POP3.
Kafka
Mon Mar 06, 2017 11:12 am
Thanks for your patience. Mozilla Support tells me that it is not possible to convert IMAP to POP3. I think that I will just have to resign myself to the existence of the Spam folder in Thunderbird. I am still surprised that so much spam escapes Mailwasher's notice.
Mon Mar 06, 2017 6:40 pm
Kafka wrote:I am still surprised that so much spam escapes Mailwasher's notice.
No, it does not. :nono
If you really need help, disclose the details that I have already asked for . . . . . . . . . twice:—
Mon Mar 06, 2017 6:51 pm
Kafka wrote:Mozilla Support tells me that it is not possible to convert IMAP to POP3.
That's utter nonsense from Mozilla:—
I do not use Thunderbird — just delete your Thunderbird IMAP protocol and create a new POP3 account.
Kafka
Wed Mar 08, 2017 10:55 am
The details you have asked for, I assume, relate to whether I am using IMAP or POP3 for my Thunderbird and Mailwasher accounts. My main account in Thunderbird (the one containing spam) uses IMAP whilst my secondary account uses POP3. Mailwasher uses IMAP. Mozilla, as I have said, tells me that while I can change from OP3to IMAP I can't change from IMAP to POP3. You describe this as garbage, but I am hesitant to try in case I muck up my account. Also, I don't know the steps involved. As for your insistance that spam doesn't get through Mailwasher, the evidence would seem to prove otherwise. As I said previously, I always check and wash my mail via Mailwasher before looking at Thunderbird. Despite this, there is almost always a large amount of spam (which hasn't shown up in Mailwasher) in the Thunderbird spam folder.
Wed Mar 08, 2017 5:56 pm
Kafka wrote:The details you have asked for, I assume, relate to whether I am using IMAP or POP3 for my Thunderbird and Mailwasher accounts.
No, you assume wrong — need to disclose (if not Gmail, then) which e-mail service are you using? :facepalm
Kafka wrote:As for your insistance that spam doesn't get through Mailwasher, the evidence would seem to prove otherwise.
Your "evidence" is based on a faulty implementation. :)
Kafka wrote:Mozilla, as I have said, tells me that while I can change from OP3to IMAP I can't change from IMAP to POP3. You describe this as garbage, but I am hesitant to try in case I muck up my account.
In that case, you might want to re-post your issue at the Mozilla forums? :thumbsup
