Mailwasher Pro 5.6.3 hanging
scbs29
Sat May 20, 2017 11:27 pm
Hello all
I suddenly have problems with MW 5.6.3. I have run MW Pro 5.6.3 and Zemana Antilogger for well over a year with no problems. Suddenly Antilogger starts and after 5 minutes tells me that it
is frozen. Since this has happens then MW will not run either. The MW window opens and then freezes. I tried the suggestion in hxxp://forum.firetrust.com/viewtopic.php?f=13&t=19909
but it made no difference. I found a tmpLog.txt file in AppData\Roaming\Mailwasher Pro which contains:
·Program Started - ver 6.5.3
·20/05/2017 11:47:14
·Windows NT 6.1.7601 Service Pack 1
·System uses a local area network to connect to the Internet
·Machine is currently connected to the internet
·Command line: "C:\Program Files (x86)\FireTrust\MailWasher Pro\MailWasher.exe"
·MailWasher Pro data path: C:\Users\stuart\AppData\Roaming\MailWasherPro\
·HTTP Proxy: could not obtain proxy details
·Compile settings: 8A9981D354
As I said, this only occurs when Zemana Antilogger does not run.
Has anyone else come across anything like this ?
Re: Mailwasher Pro 5.6.3 hanging
Sat May 20, 2017 11:50 pm
scbs29 wrote:I have run MW Pro 5.6.3 and Zemana Antilogger for well over a year with no problems.
Regardless of the past history, of your 5.6.3, it is highly advisable to update to the latest 6.5.4 — your MailWasher has remained un-updated while the Zemana Antilogger has kept itself updated (and possibly, stopped loving your outdated MailWasher.)
scbs29 wrote:As I said, this only occurs when Zemana Antilogger does not run.
You might also want to add the following exception to your Zemana Antilogger:—
  • Code: Select all
    C:\Program Files (x86)\Firetrust\MailWasher Pro\MailWasher.exe
scbs29
Sun May 21, 2017 3:13 am
Thanks for the reply.
I did as you suggested and it seems ok now.
