Error: List index out of bounds (0)
tek
Fri Sep 19, 2008 4:15 am
My MWP has been flawless for years. This morning when I went to open it up I get this error msg:
"List index out of bounds (0)"
The app does not come up. But the process is already running when I try to re-open. I manually close the process and re-open MWP and the same error of "List index out of bounds (0)" comes up again.
I'm running Windows XP Pro and MailWasher Pro 6.2.1.
I had older version and just updated to correct the problem. Both app versions produced the same error.
Your help would be appreciated. Thank you.
Re: Error: List index out of bounds (0)
Fri Sep 19, 2008 4:59 am
Try deleting the column information from the MW registry key if you are skilled at registry editing, if not and you oops you can make a mess of your system and using the MW option to clear the registry is a much safer option.
http://wiki.castlecops.com/MailWasher_P ... eceived.3F
tek
Fri Sep 19, 2008 5:33 am
Ok, I think I have it fixed. Thank you for your reply and link.
What I did was reinstalled and fiddled with all the option settings and my black and friend lists. Closed reopened and all is well.
I think something was up with my blacklist file. Maybe got corrupt?
Everything seems fine now. But if it starts again I will follow the steps according to your supplied link.
Thanks again! :lol:
-tek
