This spammer stops the domain blocking by changing the letters before the domain (see below) -------> drivefact.org
What other way could I block them? Would *drivefact.org work?
I'm thinking no because I have another pesky spammer where I tried that and it didn't work.
I'd appreciate any help you could give. Thanks,
@ekwafm.drivefact.org
@hwqxqv.drivefact.org
@xzskbe.drivefact.org
@zgwixl.drivefact.org
@fbdceb.drivefact.org
@gvyxbm.drivefact.org
Spammer changs letters before domain to stop blocking
- zki529
Re: Spammer changs letters before domain to stop blocking
Yes, *drivefact.org would work just fine.
When you add the entry to your blacklist just be sure you click the option first Wildcard Expression >> then enter *drivefact.org in the field >> Add.
