Gmail errors
dsicon
Gmail errors
Sat Nov 07, 2020 1:45 pm
Gmail has been working fine until a few days ago. Now I get constant streams of errors but it does still work intermittently. What can I do?
It says Failed to log in
Re: Gmail errors
Sat Nov 07, 2020 5:23 pm
How intermittent does it work ?
Also be good to know what version MailWasher you are using. You can check under Help >> About.
Also how long between each automatic checks in MailWasher, and are you using POP or IMAP in MailWasher to check the account ?
dsicon
Re: Gmail errors
Sun Nov 08, 2020 12:18 pm
IMAP, Mailwasher 7 I posted in wrong forum
If i go to GMAIL and refresh the errors clear and then recur
Re: Gmail errors
Sun Nov 08, 2020 12:43 pm
OK, can you try sending me some logs.
Go Help >> Send Support Logs >> enter a brief note like 'as per forum' >> in the Ticket Number field enter chris >> Send Logs >> reply back here once sent, so I can be sure they arrived all OK.
Re: Gmail errors
Mon Nov 09, 2020 9:16 pm
OK great. The logs have this error when MailWasher tries to check the GMail account.
11-08-2020 07:57:51.832 Info C: LOGIN *******
11-08-2020 07:57:52.886 Info IMAP SERVER LOGIN: *NO [WEBALERT] Web login required.
Check here that Less Secure Apps is enabled https://myaccount.google.com/lesssecureapps
Or alternatively create an App Specific Password to use in MailWasher. Your regular GMail password is the same still, the App Password is for use in programs like MailWasher.
