Mailwasher Free 6.5.4 - Not showing some emails
GrumpyOldMan
Thu Nov 19, 2020 7:49 pm
Hello
I'm having a problem that's just recently started. Some (only some) of my emails are being shown as empty, with no sender and the only thing that shows in the Email Info is a Return Path in the header!! These are all legit emails from senders in the Friends list and all my emails come from the one server.
Downloading the email with Thunderbird gives the full email including the senders details and full header. I've set the number of lines downloaded per email to 450 but this doesn't seem to help. Emails come from an IMAP server, port 993 and some of my emails come through without a problem. This started on 5 November 2020.
Thanks for any help.
GrumpyOldMan
PS Just downloaded 7.12.29 and will see if this fixes anything.
PPS Yep that fixed it, please delete post if necessary. Incidentally which .EXE file needs to be waved through the Firewall for updating, I have to switch my Firewall off to check for updates.
Re: Mailwasher Free 6.5.4 - Not showing some emails
Thu Nov 19, 2020 7:54 pm
Great.
If you want to go back to 6.5.4 Free, then under Tools >> General Options >> there is a Spam Throttle on how many lines per email to download, if you set that to a higher number, say 500 lines >> click OK.
That will probably fix the issue you described.
