Greetings,
I was just wondering if I'd have any issues upgrading from the Beta which I still am using!?
I trust that I won't have to purchase the latest version (I am a registered/licensed user).
Kindest regards,
James
Upgrading from MWP 6.1.1.29 Beta to 6.3...
- Dragan Glas
The only secure computer is one that's unplugged, locked in a safe, and buried 20 feet under the ground in a secret location... and I'm not even too sure about that one
Dennis Hughes, FBI
Re: Upgrading from MWP 6.1.1.29 Beta to 6.3...
No issues upgrading, if you aren't a beta forum member here you can PM rustic dog and get access if you are a tester.
The upgrades to 6.3 is free, it should just load and run with no problems. Do make sure your old version isn't running when you install.
- Dragan Glas
Greetings Stan,
Thank you!
Upgraded without any problems!
Kindest regards,
James
Thank you!
Kindest regards,
James
Dennis Hughes, FBI
