I can't find the Recycle Bin
jtimothy
Thu Dec 31, 2020 8:33 am
Like the program, will probably get the Pro version, but I may be dense but I can't find the Recycle Bin. Directions say use the Recycle tab on the Menu; I don't see it. Directions say, go to the Tools tab and then click on Recycle Bin; I don't see the Tools tab. I'm at a loss. I've clicked n everything I see. Any suggestions? Thanks.
jtimothy
Re: I can't find the Recycle Bin
Thu Dec 31, 2020 8:54 am
There is a Recycle Bin tab under "Settings" but it does not give me a list of deleted emails.
Thu Dec 31, 2020 12:12 pm
Yeah that got removed, so in MailWasher Free there is no Recycle Bin tab. It would usually sit between the Inbox and Settings tab.
You could try the trial version of MailWasher Pro as well, that will have everything fully active for 30 days
