When I get mail in Hebrew MailWasher Pro uses a tiny and almost unreadable font size (5pt I suppose),
Is there any way to decide which font and font size are used in preview?
Changing font / font size in preview pane (MWP 6.5.4 Windows 10)
- Adam
Re: Changing font / font size in preview pane (MWP 6.5.4 Windows 10)
Nobody? Really ?
I repeat the question:
How to change the font / for size used in preview pane - is it some Windows default? Do I have to use Regedit? Change something in an .ini file ?
Someone surely knows the answer to this.
It is really hindering my possibility to use the software.
Thanks in advance
Thanks in advance
Unfortunately not, that version of MailWasher uses a fixed font size which can only be altered by increasing the overall font size in Windows.
- Adam
Strange since Hebrew font worked perfectly in XP and 7 for this same version of the software?
Can you find out which font specifically we are talking about? (i.e. is used by the code). Perhaps that font in not installed in my Win 10 and it is using a "replacement" font.
I would be grateful for any help in this matter.
It most likely will be Arial, though we don't have any programmers to work with this old version of MailWasher, so I can't get anything confirmed.
Unfortunately I cannot think of any nice way to improve this, Windows 10 also doesn't allow font scaling in individual applications. Obviously there is the newer MailWasher 7.x, which has built in font scaling, but that has a cost associated. If you just have the one account then the free version ought to be fine
- Adam
Thanks, but I was not offered a free version - I have only one personal account and I bought a "lifetime" license years ago but now I am expected to pay US $ 90 for another "lifetime" license - I must be a cat with many lives
So where can I download a free version of 7 - a fully functional one I hope? The one offered on the site expires after 30 days?
And if I get ver. 7 is there an easy way to port the accounts and filter info from 6.5.4 to 7 ? There is no export option but perhaps a file with this info is available?
The free version does have some limitations, can be gotten from https://www.mailwasher.net/
There is no filter import, but the import wizard should pick up the existing MailWasher accounts and some other settings just fine.
- Adam
OK I see the free version handles just one email account but I have more accounts.
Thanks for the answers
