Just to report an issue:
I've been running MWP 6.5.4 for several years, and in the past few weeks Comcast is randomly sending SSL errors when 6.5.4 logs into multiple accounts at the same time, and individual accounts to a lesser extent.
It has forced me to upgrade to MWP 7 which connects to comcast.net normally. FT Support suggested it could be that Comcast is moving to SSL 1.2 - does that sound right?
-Ed
MWP 6.5.4 - SSL errors with Comcast.net servers
Re: MWP 6.5.4 - SSL errors with Comcast.net servers
Yeah, that will be right, the old MW 6 has outdated SSL library files.
You can replace the SSL files with ones I posted here viewtopic.php?f=13&t=32973#p134300
However it does seem to generate an error on first mail check, then runs OK.
