Mail Washer 6.3 Hangs when Processing
- jmkays
When I click on "Process," Mail Washer hangs, forcing me to close the program with Task Manager. Under settings, I have the app. set to sequentially check my accounts (two accounts). It retrieves mail without hanging, but will not process -- delete spam, etc. I'm using Vista 64bit Ultimate. Never had this problem with previous versions of the software. Please assist.
Re: Mail Washer 6.3 Hangs when Processing
Are you using the bounce option, it can cause problems and is not an effective tool these days?
- jmkays
You have multiple CPUs ?
Try setting MW to run on only one CPU....I think that's done from Task Manager ?
- jmkays
Tried selecting one of four cores on my quad core system (QX9770 running on a 790i Ultra mobo). No luck. I haven't upgraded since v5.3. Would really like to use this new interface and features, so hope there is a workaround.
You could send me your PC for ummm.....testing ?
The 5.3 upgrade shouldn't have been a bother, but just in case, let's clear out some of the obvious files that MailWasher writes to when you Process Mail and see if that helps.
First in MailWasher go Settings >> Recycle Bin Options >> empty the Recycle Bin here, clear the message logs >> click OK.
See if that helps....
If not, then go Help >> About >> open the link to the data files >> then go back and close MailWasher >> back in the folder you opened rename "Training" to something like "OldTraining" >> restart MailWasher and see if that helps.
This will unfortunately also mean needing to retrain MailWasher from scratch which messages are good and bad.
- jmkays
I think there may have been a corrupt file in the app data folder. I backed up the friends and black list filters, restored them after deleting the entire app folder and restarting Mail Washer. That appears to have fixed the problem for the moment, but won't be certain until I have more email to work with. Should know in an hour or two.
Thank you for the tips.
Update: that seemed to fix it. Must have been a corrupt log file.
