Mailwasher 7 now fails to start
bones
Fri May 13, 2022 7:22 am
After yesterday's W11 upgrade (may 10th), Mailwasher will no longer start. Error messages says,
"The application was unable to start correctly (0xc0000135). Click OK to close"
Any solution for this?
I have restarted the PC and no luck there so I uninstalled and reinstalled MW. It still gives the same message. :(
Re: Mailwasher 7 now fails to start
Fri May 13, 2022 12:36 pm
Try running a .NET Repair, takes around 10 minutes.
If that still fails, try going into C:\Users\[your username]\AppData\Roaming\Firetrust\MailWasher and delete startup.xml and try again.
bones
Fri May 13, 2022 7:25 pm
I tried the .NET repair - no luck with that. Then it got interesting.
Two updates were released on May 10th:
Net Framework KB5013628
Windows 11 UD KB5013943
I uninstalled both and rebooted the PC. On restart Mailwasher was working again (temporary Yayyy!!!)
I then reinstalled Net Framework Update KB5013628.
Rebooted PC.
On restart Mailwasher was back again.
Then I reinstalled W11 Update KB5013943
Rebooted PC.
Back came the "The application was unable to start correctly (0xc0000135). Click OK to close" massage for two programs. Mailwasher was one. ArmouryswAgent was the other.
Uninstalled KB5013943 again and I've got Mailwasher back, but am being nagged to install the W11 Update again. :(
Sat May 14, 2022 12:32 am
OK, it does seem like this is known issue with the update.
Resetting .NET may do the trick, you can check out this link for details
https://www.techadvisor.com/how-to/wind ... s-3815822/
bones
Sat May 14, 2022 11:39 pm
I looked at the Tech Advisor link.
It shows how to turn off the NET Framework update ( which was not an issue), but it doesn't help with the W11 Security Update KB5013943 which causes the 0xc0000135 failure with Mailwasher. So, for now, I have uninstalled the update and hope that a fix will soon be in the pipeline. How's that for eternal optimism. :)
T11
Sun Nov 13, 2022 2:24 pm
It fails to start for me too
JimE
Sat Sep 02, 2023 10:21 am
Today Mailwasher 7 all the sudden Now fails to start for me. I tried everything on this page, nothing works, all just a waste of time trying.
Then I found the "MWPImportUtil.exe" file and after executing & restoring my settings everything worked fine, back up & running now.
File location:
C:\Program Files (x86)\Firetrust\MailWasher\MWPImportUtil.exe
lars.nilsson
Sat Sep 02, 2023 6:36 pm
I have the same problem - MailWasher fails to start.
I located the exe file you suggested, but how do I use it? It asks for a location to import from.
Steve3nj
Sat Sep 02, 2023 10:32 pm
Last night, my mailwasher disappeared and I could not reopen it. Today, on my other computer, it does not open. I have version 7. Please help. Thanks.
rodan65
Sun Sep 03, 2023 1:27 am
As of this morning my Mailwasher Pro keeps quitting to the desktop, it loads, gets emails from outlook, but before any spam checking / filtering is carried out, it just crashes / quits. No error messages, nothing, just quits. It worked fine yesterday, I don't think there were any windows updates, there doesn't appear to be any when I check windows update.
I've tried doing .Net repair thing with the download from Microsoft, no change.
Tried deleting the startup.xml file, again no change there, still just quits.
Outlook itself works fine, gets emails.
Any suggestions?
Edit - found the following in Event Viewer - windows 10 x64 btw
Application Error Event ID 1000
Faulting application name: MailWasherPro.exe, version: 2023.7.12.173, time stamp: 0x64eabb1f
Faulting module name: MWPappDLL.dll, version: 0.0.0.0, time stamp: 0x64e8204c
Exception code: 0xc0000005
Fault offset: 0x000df5c4
Faulting process ID: 0x74f4
Faulting application start time: 0x01d9dd9fe00a3b57
Faulting application path: C:\Program Files (x86)\Firetrust\MailWasher\MailWasherPro.exe
Faulting module path: C:\Program Files (x86)\Firetrust\MailWasher\MWPappDLL.dll
Report ID: 37c9eda5-289b-4e34-a767-04ad02000ed0
Faulting package full name:
Faulting package-relative application ID:
.NET Runtime Event ID 1026
Application: MailWasherPro.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 779DF5C4
tjerin
Sun Sep 03, 2023 3:53 am
I just started having the same issue this morning. Is there a fix available?
krissully
Sun Sep 03, 2023 4:40 am
No hope here. Crashes every time since latest update. PLEASE RESPOND.
tjerin
Sun Sep 03, 2023 4:48 am
I discovered that my issue was related to something in the Yahoo account JUNK folder. When I cleared that folder using theYahoo mobile mail client and then ran MWP it doesn't crash. So for now I have un-selected the Yahoo JUNK folder in MWP IMAP settings so MWP won't try to evaluate any emails in that folder.
Sun Sep 03, 2023 5:57 am
Please try what is recommended here:
viewtopic.php?f=50&t=58383#p167431
Should fix the crashing issues....
rbaroncpd
Thu Nov 16, 2023 8:21 am
There is an update that fixed my problem with Mailwasher Pro.
Go here: https://www.firetrust.com/products/mail ... o/download
Install it and you should be good to go.
Rich
