Mailwasher pro 5.3
quicksilver1952
Mailwasher pro 5.3
Tue Jun 11, 2024 9:09 pm
Over the last couple of days I get Session encountered errors 'Error connecting with SSL' for every session using my
[email protected]
email.
I have not changed anything in my BT email or Mailwasher settings.
Can you help?
Barry
Re: Mailwasher pro 5.3
Thu Jun 13, 2024 7:13 am
Yes, very likely your ISP has stopped support for the older SSL method MWPro 5/6 uses, only our later MWPro 7.xx version has been updated to the new SSL method....
To test this, install either MWPro trial version from here:
http://www.firetrust.com/products/mailw ... o/download
OR the free version from here:
https://www.mailwasher.net/download-mailwasher-free
(Note) that this wont effect your 5 or 6.xx version at all)
OR, below is another option to try out first if you wish.....
We have recently found that sometimes you can get the new SSL working by extracting and placing the attached files in the install folder, replacing the old.
This folder is usually:
C:\Program Files (x86)\Firetrust\MailWasher Pro
It will generate a failure to load SSL libraries on startup, but setting MW to Suppress All Errors will hide that:
Tools>>Show Errors Digest, tick, "suppress all errors">>OK.
It might also require MW to be set to sequential checking also.
Settings>>Connection Options, select, "sequential checking">>OK
MWP-SSL.zip
(855.52 KiB) Downloaded 238 times
LouLockman
Thu Sep 12, 2024 10:21 pm
I am also experiencing the same situation as above but thanks to your writing, I learned and followed it and have overcome that situation, thank you for sharing.
