The error "Contactslib.dll not found" has started to show up every time Mailwasher starts since I have reverted back to v6.5 from v2010.
I have uninstalled 2010 and then reinstalled v6.5 twice but the error persists.
I installed 2010 but did not like it because of the way the screen jumped about when changing the status of the entries in the list. I sort the list by status, so for instance if I changed an entry which has no defined blank status to SPAM status (Showing near to the top of the list), the screen would jump to the spam listings (which are near the bottom of the list) and I had to scroll all the way back up and find the part of the list where I had been previously working.
The other thing I did not like about 2010 is that Zonealarm is constantly active when mailwasher 2010 was installed. Because ZA is constanly active it is impossible to tell if there is any strange or unauthorised activity on the connection.
I still love 6.5 and still think that Mailwasher is one of the best investments in software that I have made.
Ray
Contactslib.dll not found problem
- raygee
- nhow
Re: Contactslib.dll not found problem
I'm having the same problem. Since going back to MW Pro 5.3 which I greatly prefer to later versions, I now get the contactslib.dll errror every time I start up. Really annoying.
- TrustFire
The 6.54 has various bug fixes as compared to the 5.3 :-
http://www.firetrust.com/products/mailwasher-pro/6/download
- nhow
Thanks but I prefer 5.3
TrustFire wrote:The 6.54 has various bug fixes as compared to the 5.3 :-
- TrustFire
In that case, you'll have to live with those errors - it's not possible for us to help you.
nhow wrote:TrustFire wrote:The 6.54 has various bug fixes as compared to the 5.3 :-
