"List Index Out of Bounds" MW 6.5.0
angelah
Tue Nov 30, 2010 11:29 am
I'm getting a "List Index Out of Bounds" error message on Mailwasher 6.5.0.
When I click the MS icon, MS never opens just gives me this message.
HELP!
THANKS!
ataraxy
Re: "List Index Out of Bounds" MW 6.5.0
Tue Nov 30, 2010 2:08 pm
Windows 10
Wed Dec 01, 2010 3:08 am
You might want to upgrade to the latest version of MW 6 while you are working on this, it may have a few less problems.
http://www.firetrust.com/en/products/ma ... ro/support 6.5.4
rykis
Wed Aug 26, 2015 1:21 am
Sorry for bumping up such an old topic.
But this topic is what you get when you google "Mailwasher 6.5.4 List Index Out of Bounds".
I came across this problem yesterday.
You have to know that "-restore" will DELETE ALL accounts, settings, filters, and registration, so better back them up.
I managed to fix "List Index Out of Bounds" issue different way - by deleting registry entries one by one.
For me it was:
[HKEY_CURRENT_USER\Software\FireTrust\MailWasher Pro\Prefs]
"column order"=""
"column widths"=""
These entries can't be NULL !!!
So just delete completly two keys above and program will start with no data lost.
Hope it will help someone.
Greetings from Poland :)
ataraxy
Wed Aug 26, 2015 4:55 pm
Thanks for the feedback.
Windows 10
StanS
Thu Jun 16, 2016 9:36 am
Thanks rykis!
I'm using Mailwasher 6.5.4, and was getting the "List index out of bounds" error. I went and looked at "column order" and "column widths" in the registry [HKEY_CURRENT_USER\Software\FireTrust\MailWasher Pro\Prefs], and was about to delete them as you mentioned, but instead I Copied & Pasted the values from another system and it easily fixed the problem.
See a screen shot of the registry before and after here, http://i.imgur.com/oPP3KCa.png.
