Will Benign work with Windows 7?
Patrice
Sun Aug 28, 2011 8:10 am
Not just Windows 7, but also a 64 bit system? If so, I'll transfer it to the new computer. If not, what would you suggest to replace it?
FWIW, B9 and Mailwasher have saved my computer at least a dozen times, probably more, over the years. I'd hate to be without either.
Thanks!
Patrice
...From the Greenhouse
Clay L
Re: Will Benign work with Windows 7?
Tue Jan 17, 2012 4:22 am
This is late, but yes it will work with Win 7 64 bit.
I am having trouble with B9 now after a crash and clean reinstall of Win 7, but B9 worked fine with it for about three years.
