E-mailing a summary
clauderenaud
E-mailing a summary
Thu Nov 27, 2008 9:25 am
Hi all,
The SMTP server I use (smtp.yahoo.com) unfortunately needs authentification but there is apparently no place to enter those specific settings (as it is possible in MailWasher)...
Is there a trick to bypass this Benign limitation ?
Regards,
Claude Renaud
Re: E-mailing a summary
Thu Nov 27, 2008 12:51 pm
Benign only filters Incoming Mail (POP3) not Outgoing (SMTP)
So there should be no need to setup Benign for this
Chris
clauderenaud
Fri Nov 28, 2008 9:35 am
rusticdog wrote:Benign only filters Incoming Mail (POP3) not Outgoing (SMTP)
Chris
I'm speaking of the "E-mail a summary" group options you can find in the general tab of the option dialog box.
Here you can specify an e-mail address and a SMTP mail server.
The problem here is that the smtp server I use need authentification, settings we apparently can not set up here ...
So what to do ...
Regards,
Claude Renaud
Fri Nov 28, 2008 10:38 am
Ah, you are right there.
I guess then unfortunately you'll not have to set summaries to be sent. Once we worked through all our other projects we'll be taking another look at Benign, but that is some time away.
clauderenaud
Fri Nov 28, 2008 10:57 am
rusticdog wrote:Ah, you are right there.
Ok, so I will try if my ISP's smtp server work and take you aware of ...
Regards,
Claude Renaud
