key
pocsta
key
Sat Sep 10, 2011 1:31 am
Hello I bought mailwasher pro recently, but since then i have upgraded my hardware on it so i had to use my key again i then unfortunately had to reinstall windows using my key again :( and since then i have also upgraded to 64 bit so when i tried my key again it said i have used the key too many times, what can i do?
Re: key
Sat Sep 10, 2011 3:29 am
Did you see this note in the forum header?
Please no questions related to MailWasher
There are forums for MW 2011 and the older v6 where you should ask this.
2011 http://forum.firetrust.com/viewforum.php?f=50
v6 http://forum.firetrust.com/viewforum.php?f=13
Guessing you are using v2011 and are on version 1.2.0 or 1.2.3 you should e-mail support at firetrust.com with your registration details and have the key reset.
