When I wash my mail, and then select, mail program Outlook Express 2010, it does not show my washed mail, it does not show any mail at all, I have tried three or four times, but no luck.
I am using Mall Washer Pro.
Barry Page
[email protected]
My washed mail
- ataraxy
- Knowledgeable Kea
Re: My washed mail
What happens if you click on "Get Mail" in Outlook (that may not be the exact command but it will be something similar - I don't use Outlook)? Is your mail downloaded then?
You should probably remove your email address from your post above. Leaving it there makes you a target for the spammers.
Windows 10
