TuneUp utilities
Re: TuneUp utilities
Mon Nov 28, 2011 9:12 am
You're seeing this in Firefox aren't you - try to browse the same sites (where you hear those funny sounds) with Internet Explorer, you probably wont hear them.
Confirm the above and we'll tell you how to get it resolved.
Mon Nov 28, 2011 9:49 am
Run your TuneUp installer again - it should display the option to repair your corrupt installation with fresh files.
Mon Nov 28, 2011 10:06 am
You can download the trial installer from the TuneUp Utilities homepage.
Mon Nov 28, 2011 10:33 am
You're welcome - the cursor should be fine after a reboot. :thumbsup
Tue Nov 29, 2011 5:34 am
You don't need to pay for it again - just check your inbox for (around the date) the order was placed and you should find your product key which needs to be only entered into the trial installation (which incidentally come fully functional even during the evaluation stage.)
Tue Nov 29, 2011 6:11 am
Can you navigate to your services and disable all TuneUp related services - except 'TuneUp Theme Extension.'
Reboot and report whether the problems persist.
Tue Nov 29, 2011 6:50 am
Unfortunately, you're on XP - I'm running Windows 7. Nonetheless, running the following command should bring up your services.
Code: Select all
services.msc
Tue Nov 29, 2011 7:33 am
Buckyg wrote:The only TuneUp related sevices I see is TuneUp Utilities.
Yup, this is the one - you got to disable this one before rebooting to confirm your issues.
Buckyg wrote: Right above it is Themes and it says it is, Provides User Experience Theme Management
Please leave this one alone - otherwise, it will cause you grief.
Tue Nov 29, 2011 7:56 am
Buckyg wrote:There is no option to delete it, all I could do is STOP it, which I did and rebooted. Still same problems.
Right, you need not delete - just disable.
Buckyg wrote:Still same problems.
What this confirms is that your problems are not related to TuneUp Utilities - it's something else. Unfortunately, I'm done for the day - it's past midnight this side of the Continent (got to get myself some shut-eye.) Hope somebody helps you out . . . . . in the meantime.
Wed Nov 30, 2011 3:21 am
Hey, thanks for posting back the solution here - we're glad you overcame your issue. :thumbsup
Edit:-
As per your preference, you may also restore the TuneUp Utilities services back to 'automatic' if you wish to.
